YS Engines Support Direct support from YS Performance Engines by Dave Shadel
YS 170 CDI on low nitro
Old 08-15-2011 | 06:02 PM
Enrique-F3A's Avatar
Default YS 170 CDI on low nitro
Hi all,
Accordingly to the DZ170CDI Operator's manual, this engine could be used with less than 30% nitromethane. The manual states textually:
" Use a good quality alcohol based model engine fuel containing 0% to 25% nitro, and oil content 5% to 25% ............"
Is anyone using this engine on low nitro, say 10-15 % ? . If so, How does it perform regarding reliability and power ? . Of course, I don't expect the engine to have the same power on 15 % nitro, but, does it do the job, I mean P-11 (P-13) F3A schedule ?
Thanks in advance for your inputs !
Enrique
Old 08-24-2011 | 06:46 AM
My Feedback: (45)
Default RE: YS 170 CDI on low nitro
Enrique,
I flew mine on 15% Cool Power last year before I switched to electric. The motor performed great and had good power. Obviously not what it does on 30%, but it wasn't bad. There was about a 400 RPM difference between 15 and 30. I was running the 19X11 on the 30%, but liked the 18.1X11 on 15% as it let the motor spin a similar RPM around 7500 which it was very happy at. If your plane is fairly light, I doubt you would notice a significant difference. If you are close to 11# and running on a hot humid day, you might want a little bit more.
Arch
Old 08-24-2011 | 05:07 PM
Hello Arch, thanks for your complete and helpful comment. By the way, how do you like electrics ?. Do you feel confortable with it or are you missing the glow ? Do you think you will stay with electric pattern ? I have not been able to decide what to do about that, a lot of information for and against the electrics confuses me.
Regards
Old 08-24-2011 | 10:27 PM
hello Arch
Can you please explain the exact reason why the 170CDI could be used with less than 30% nitromethane,
And my engines I have DZ160 Can not work on 15% Cool Power ?
kobi
