YS Engines Support Direct support from YS Performance Engines by Dave Shadel
YS 63 below half throttle problems
Old 08-22-2003 | 12:05 AM
Default YS 63 below half throttle problems
Dave, This is my first YS 4 stroke... experienced with several YS Heli motors... Here is the problem
20/20 fuel, OS F plug, 13x6 APC prop. Mounted on a Funtana. I am getting 10,600 rpm and 2000 ppm idle.
Starts ok, warm it up and take off. The funtana does not require full power so most of the flying is around 1/3 to 1/2 throttle. After prolonged flying at lower power setting (1 to 2 min) the engine starts to sputter like it is rich. Playing the throttle when it first starts will clear it. Sometimes this results in a dead stick.
After the run the tank is bulging with pressure. Fuel filter going into carb is clean.
Main needle is 1 1/4 and Idle screw is flush with the barrel.
The APC Prop might sound like it is too much but it is a narrow blade version that is revving to 10,600.
I figure it is a cross over problem... ie idle to pressure delivery. I guess I do not understand the idle screw...is is an air-bleed or fuel quantity mixture screw? The transition seems good on the ground.
Any help appreciated.
TIA
Bert
Old 08-22-2003 | 12:32 AM
The idle screw is an air bleed. Clockwise is richer. It should have no effect on the midrange. At 1/4 throttle you are already above the suction to pressure point. I never idle them that slow as I like to be into the regulator at idle. 2300 or so will do it.
My guess is that the regulator is set to rich, but I could be wrong. Try running the reg in about 1/2 turn and see if it improves.
Old 08-22-2003 | 01:03 AM
Thanks Dave I will give that a try...
