YS Engines Support Direct support from YS Performance Engines by Dave Shadel
THIRSTY YS63
Old 12-24-2003 | 01:54 PM
Default THIRSTY YS63
Hello
I have a YS 63 which has had around 2 and a half gallons of fuel through it and runs very well. The only downside is that it uses 9 oz of fuel in 8 minutes!
Is this normal ? I am using Yamada mix 20/20 from Model Technics, a OS 4 stroke plug and an APC 13 x 6 prop and the standard muffler.
I thought I saw that they were supposed to use 1/2 an oz per minute.
This time of 8 mins is not all full power as I unable to fly full power for long as the plane is very light and this engine is very powerfull.
No real problem but I will have to think about putting a larger ( lot larger) tank to get any kind of flight time, and I,m a bit pushed for space as it is.
Many thanks for any feedback Rodders
Old 12-25-2003 | 01:51 PM
Default RE: THIRSTY YS63
That is about right. Decreasing the prop size will result in greater run times.
Old 12-26-2003 | 07:21 AM
Many thanks Dave
I will see about trying to get a 14 oz tank in the plane.
Old 12-26-2003 | 10:17 AM
Good Flying!
