YS Engines Support Direct support from YS Performance Engines by Dave Shadel
YS63
Old 01-13-2004 | 08:42 PM
c/f
Default YS63
I bought this engine when they first hit the streets, it ran flawless out of the box, idled reliably on PowerMaster ys20/20 and had the power greater than most .60 two strokes. I definately thought I would never buy a two stroke again as this little powerhouse weighed as little as a .46 and power of a .70. Well after about 3 gallons it just no longer wanted to transition smoothly, I only have 5 gals maybe through it total and it has become my least favorite engine on reliability issue. A am confident no leaks exist in tank and plumbing, and no debri is present in ports, timing was also checked with brass shim feeler gauge to .007. It seems to idle fine and full power fine it's just the lower center transistion thats a pain in the butt.
Where do I start, I am highly regarded at my home field as a 2-cycle engine guru but these YS are a horse of a differant color, Ive read the website and comprehend how it works, what am I missing to get that out of the box transition reliability back again.
Old 01-14-2004 | 11:13 AM
Default RE: YS63
Why not take a look at the setup instructions at www.ysperformance.com It sounds like all you need to do is re-adjust the regulator.
Old 01-15-2004 | 07:26 PM
c/f
Default RE: YS63
Wow, OK Brief and to the point?
Dave
What symptons does the piston mods being performed by Performance actually cure?
What symptons would a leaking valve cover gasket create?
What symptons would a regulator spring that has lost tension create?
What is the oring size/dimension of the needle valve.
Thanx in advance.........
Old 01-16-2004 | 11:03 AM
Default RE: YS63
1.surging at top end
2.lean throughout the range
3.makes transition richer, rare that this would ever be an issue.
4.metric, finding a replacement in the US except from us will be very tough.
I HAVE to be brief and to the point! The days don't have nearly enough hours for everything I do!!! >)
Good Flying!
