Stripped thread in crankcase
Hi Dave,
Can you help? I've stripped the thread in one of the holes in the rear crankcase, one of the two that the long dia. 3mm x 35mm long bolts go into to hold the back plate assembly on. Is there anyway to repair this or can a slightly larger bolt be used instead e.g. 6-32 or M3.5?
Regards
Keith
Regards
Keith
The right fix is a new case, but you can try a 3.5mm bolt if you can find one long enough. I don't like band aid fixes though, as they can cause other problems.
