YS Engines Support Direct support from YS Performance Engines by Dave Shadel
140 DZ Hand start or Starter ??
Old 06-27-2002 | 03:29 AM
Default 140 DZ Hand start or Starter ??
My New DZ will be here in a couple days :~)))
In the past I have hand started my other 4-strokes including my saito 180's, wearing a welding glove, pull the prop through till it Bumps with glow igniter on it ( Holding on to it tight) then flip prop backwards and we have ignition.
Is it possible to start the DZ in the same maner ? (by hand)
or should I be using a starter with this particular eng?
TIA
Jeff
Old 06-27-2002 | 11:48 AM
The fuel system in all YS engines requires that they be started with an electric starter. You cannot spin the engine fast enough by hand to make fuel reach the engine.
Old 06-27-2002 | 12:15 PM
Thanks Dave, I have the Sullavan starter now, will that work or should I look at getting the Dynatron HD starter?
Jeff
Old 06-27-2002 | 01:09 PM
The standard Sullivan will work fine. Just make sure it has a good battery.
Good Flying,
Dave
