YS Engines Support Direct support from YS Performance Engines by Dave Shadel
Regulator Plunger
Old 05-07-2004 | 12:14 PM
My Feedback: (43)
Default Regulator Plunger
Dave,
Is the brass weight really needed in the regulator? I have been told it is not, and all of my NC's run fine without them.
jeff
Old 05-07-2004 | 12:36 PM
Default RE: Regulator Plunger
Not necessary, pitch it!
Old 05-13-2004 | 09:57 AM
Dave,
what was the purpose of these in the first place?
Mark
Old 05-13-2004 | 10:28 AM
It was thought by the YS engineers that it would provide more consistant upright to inverted running, i.e. no mixture change. They figured out that a change in the carb was what was necessary instead.
Old 05-13-2004 | 11:14 AM
Dave, Great response time!!
How to I know if I have an old carb and need it? I have an older NC , but have put the newer needel valve in it, but have had problems with the engine dying when I go vertical and then level out or spin.
Thanks, Mark
Old 05-13-2004 | 03:27 PM
You don't need it. Try richening the regulator slightly.
Old 05-13-2004 | 07:30 PM
Thanks Dave
Old 05-13-2004 | 07:35 PM
Good Flying!
