YS Engines Support Direct support from YS Performance Engines by Dave Shadel
YS 110 HELP!
Old 05-26-2004 | 05:21 PM
Bass1's Avatar
Default YS 110 HELP!
HI, I have a YS 110 with about 3 gallons of fuel through it. It ran nicely last season but it doing something different this season. I am using an idle up switch on my transmitter set to about 300 rpms over idle. At this setting the engine will surge in rpms,then sag to near idle and surge up and down several times until it finally quits. It does this a little at idle but not nearly as much. So my question is what do I do to get this higher idle to remain constant without the surging? I am using 20% Coolpower and an OS type F plug. Thanks Ben
Old 05-26-2004 | 08:26 PM
Default RE: YS 110 HELP!
I would first go through all the running procedures at www.ysperformance.com
If it still won't behave properly, try a completely different brand of fuel. Failing that, we will have to see it in our service dept.
Good Luck!
Old 05-26-2004 | 10:03 PM
Bass1's Avatar
Thanks Dave, Will try all of the above. Ben
Old 05-27-2004 | 10:18 AM
Let me know.
