YS Engines Support Direct support from YS Performance Engines by Dave Shadel
YS 1.20 throwing props
Old 07-26-2004 | 10:42 PM
catboater's Avatar
My Feedback: (51)
Default YS 1.20 throwing props
My YS 1.20F will not throttle up without back firing and throwing the prop. It seems lean but I don't know how to adjust the low end needle. Where is it?
The engine will throttle up slowly after start up but won't throttle up warm.
I'm using an APC 17x6 prop and 30% heli, all synthetic fuel.
Old 07-27-2004 | 09:49 AM
Default RE: YS 1.20 throwing props
These engines have a fixed idle, there is no adjustment. Since it is an older engine, you have either had it a long time or bought it used. There could be mechanical problems or possibly the fuel system is in need of repair.
The starting setting for the main needle is 2 turns open, the regulator screw should be set flush with the housing. Make sure that the tank is pressurizing correctly.
Throwing props is a sign that the engine is detonating. Is the prop driver face worn smooth? If so, it MUST be replaced before going further as it will NEVER hold a prop correctly.
Old 07-27-2004 | 05:54 PM
catboater's Avatar
My Feedback: (51)
OK then. I'll send it in. What's the address?
Old 07-28-2004 | 08:47 AM
YS Service
1295 Industrial Court
Gardnerville, NV 89410
Phone 775-782-4562
