YS Engines Support Direct support from YS Performance Engines by Dave Shadel
Props for 140 DZ
Old 10-17-2004 | 08:10 PM
Default Props for 140 DZ
Dave,
I have an APC 17X 10 on my 140DZ now and it peaks out at around 8,450. I run it at 8,300. I tried a Mezjlik 18x6 and it ran up to 9,300. I prefer to use Mezjlik and the largest diameter lowest pitch that works, but I remember reading that you recommend keeping the 140DZ at 8 - 8,500. Would a Mezjlik 18x8 put it in the preferred range? Its running on Wildcat 30% Heli fuel. Since the manual shows a practical range of 7,800 to 9,000, what happens over 9,000 - do the valves float?
Old 10-18-2004 | 10:05 AM
Default RE: Props for 140 DZ
It depends on the application. Running over 9000 won't hurt it unless you do a vertical down line at full throttle, then you might float the valves. Not many guys ever run them like that, though.
Old 10-18-2004 | 11:23 AM
Ya, I'm not likely to do that either! So are you saying I'd be ok to use the Mezjlik 18x6 with good throttle management - or would I be better off to go to the 18x8? The application is sport aerobatics with mild 3D.
Old 10-19-2004 | 10:51 AM
I think the vertical will be better with the 18x6, but try both and see.
