YS Engines Support Direct support from YS Performance Engines by Dave Shadel
Difference between FZ 140 and 140L?
Old 01-29-2005 | 09:21 PM
My Feedback: (10)
Default Difference between FZ 140 and 140L?
I have a YS 140FZ and a YS 140L in front of me. They both have FZ 140 stamped on the engine lug on the same respective side. Both have 2 ni[]pples on the back plate. How can I tell which is the real 140L or 140 FZ?
Thanks.
Orlando
Old 01-30-2005 | 07:14 PM
Default RE: Difference between FZ 140 and 140L?
Does one engine have three small tapped holes in a circle at the center of the backplate?
Old 02-02-2005 | 07:54 PM
My Feedback: (10)
Dave:
The one I removed the carb body does not have the three taped hole in center of backplate. I assume then that it is the FZ and not the 140L.
Orlando
Old 02-02-2005 | 09:00 PM
The three tapped holes are on the outside of the engine.
Old 02-03-2005 | 07:36 PM
My Feedback: (10)
Dave:
Yes, they both do.
Old 02-03-2005 | 08:22 PM
You stated in one thread that one engine DOES NOT have the three tapped holes.
In your latest one BOTH have three tapped holes. Which is it??
The one with 3 tapped holes is a 140L. They were all marked FZ.
Old 02-03-2005 | 08:30 PM
My Feedback: (10)
Looking at the 2nd one. it also has 3 taped holes. They both have the 3 holes taped.
Thanks for the information.
Great help.
Old 02-03-2005 | 08:45 PM
So now they both have holes. HMMMM!
If both the engine are the same on the outside you will have to take the engine completely apart to see if it has the crankshaft sealing rings. Only a true 140L will have the rings.
Good Luck!
