Cowl Setup...
My Feedback: (14)
I just completed my cowl setup. I am running a YS63. I am trying to figure out how to work out my fueling setup. I am going to put in a fueling valve for for the mainline however, what about the pressure line with the check valve. Doesn't the check valve line have to be removed so as not to overpressure the tank when filling it. Do you use a tee and a fuel dot for this line? Will the dot hold even with the pressure that is created when running the engine?
How do most people handle this?
-Jeff
-Jeff
