YS Engines Support Direct support from YS Performance Engines by Dave Shadel
YS 120ac prop selection
Old 09-12-2002 | 03:05 AM
Default YS 120ac prop selection
I recently bought a Bucker Jungmann with a 120ac motor and I wanted to put a carbon fiber prop on it. I currently run a APC 16-8 an would like some input on proper prop selection. Also I would love to have the instruction manual for this motor. It is 5 years old and was rebuilt at 13 hrs. I only have about 2.5 hrs on it since then. It is the nicest running motor I have ever had. I love the power. Any info would be greatly appreciated.
Old 09-12-2002 | 01:44 PM
Any prop which allows the engine to run between 8500 and 9000 will work, but depending on your flying style some will work better then others.
The 16x8 is a good size to start with.
You might give Richard Verano a call at our service dept., he may have a copy of the AC instructions that he can send you.
The number is 775-782-4562.
Glad you like the engine.
Good Flying,
Dave Shadel
Old 09-12-2002 | 03:51 PM
My Feedback: (16)
I would recommend a 15x8 or 16x6 for that engine if you are looking for thrust. If you are looking for speed, then I would recommend a 14x14 or 14x10.
