Trouble with a header pipe on a 140-l
KY
The trouble is, the nut wont go down far enough to seat the flare in the threaded hole. The pipe will spin even after the nut has been tightened. This is a y.s. factory pipe. Should I send it back?
Central Hobbies has a copper washer for use under the flare on the tubing. That will tighten things up nicely.
Give them a call at 1-800-723-5937.
Good Flying,
Dave
Good Flying,
Dave
