YS Engines Support Direct support from YS Performance Engines by Dave Shadel
160DZ , first start problem
Old 04-16-2005 | 04:26 PM
Default 160DZ , first start problem
Hi Dave,
I have a 160DZ with 30-40 flights on it, runs beautifully but for one problem , the first start of the day seems very very difficult, I open the throttle and give it a nice turnin over to prime it but its still takes forever to start, after the first start it will start on first turn everytime.the needles seem perfect and I just reset the tappets so its probably not them, any help would be great
30% Coolpower
17 x 12
Hatori Pipe and Muffler
John
Old 04-16-2005 | 06:02 PM
Default RE: 160DZ , first start problem
Many of the guys here are priming the engine with a shot of fuel down the venturi for the first start of the day. Give it a try.
Old 04-17-2005 | 07:44 AM
Thanks Dave,
The Venturi isnt accessible without taking off the cowl, would make life difficult to have to remove it and prime it that way each day,couldlivve with it though,was just curious as to the possible cause as I have another 160 that starts without any priming
Thanks John
Old 04-17-2005 | 08:56 AM
I think it's probably just the pump. Is there any way to rig a priming tube so it's less problem?
Old 04-17-2005 | 06:47 PM
there would be but makes things a little bit more complicated then necessary, when you say just the pump-fixable by adjustment/cleaning or new pump?
The reason this concerns me is that with the season beginning soon I would rather have it right in case it lets me down fully one day.
Thanks Dave
John
Old 04-17-2005 | 09:10 PM
An easy way to prime the DZ for the first start is to open the throttle and use your fueling pump. Simply fill the tank, pinch the vent line, and give your fuel pump a turn or two (manual) or short burst (electric). Works great.
Old 04-17-2005 | 10:11 PM
Good suggestion.
Thanks, Earl, nice seeing you at Toledo.
