YS Engines Support Direct support from YS Performance Engines by Dave Shadel
DZ Part Replacement Help
Old 04-20-2005 | 04:57 PM
zope_pope's Avatar
Default DZ Part Replacement Help
Hi,
I have noticed that my 1.40DZ has a plastic peice that holds the fuel pump (I think thats the one on the front) in place. This has broken and the fuel pump now moves around on the rod. Two questions. Could you guide me through the replacement of the pump bracket? Also would the moving around of the pump be a possible cause of interference? I have gotten a few glitches on the last couple flights on this airplane and I was wondering if this could be a cause? Thanks in advance.
Adam
Old 04-20-2005 | 07:56 PM
Default RE: DZ Part Replacement Help
I doubt the interference problem unless you have a very poor radio. If this thing causes a glitch in your system I would get rid of this radio in a hurry.
Give Richard a call at service 775-782-4562. He can help with a part and installation.
Old 04-20-2005 | 08:58 PM
zope_pope's Avatar
Thats what I thought. No radio is brand new and works fine on all my other aircraft. I am tracing it to a bad battery I believe, but we will see. Just wanted to rule everything else out. Thanks for the info.
Adam
Old 04-20-2005 | 09:19 PM
You're welcome.
