YS Engines Support Direct support from YS Performance Engines by Dave Shadel
Exaust Header
Old 05-21-2005 | 04:33 AM
DesertHucker's Avatar
Default Exaust Header
Hi Dave,
I know this question has been asked before but i cant find it.
I broke my hatori header after it had been bent in a crash.
It is about 3" long from the side of the head, runing the engine like this could it cause any problems?
Its a 140dz on 30 nitro 20 coolpower
Thanks Lawrie
Old 05-21-2005 | 02:04 PM
Default RE: Exaust Header
Won't hurt.
Old 05-22-2005 | 06:16 AM
Hi Dave,
Had 3 great flights today.
On the 4th i think i stuffed up.
After refueling i did not turn the engine over by hand to check it.
I just connected the glow and hit it with the starter, it kicked then backfired. Mad rattling bad sounds.
I removed the rocker cover found it full of fuel.
then removed the back plate also full of fuel. Found the con-rod bent bearing in pieces gouges up the side of the crankcase. Crank journal gouged.
Gudgeon pin and piston look OK slight mark on the liner hope it will hone out.
I think were i went wrong i had the refueling line T into the supply line from the tank to the carb.
and i did not check for fuel in the engine
It is mounted inverted.
What are your thoughts Dave
Thanks Lawrie
Old 05-22-2005 | 06:17 AM
sorry Dave to do this to one of these beautiful engines
Old 05-22-2005 | 08:21 AM
It's called hydraulic lock. Liquids don't compress, and the rod couldn't handle it.
Sorry you busted it.
Old 05-22-2005 | 08:56 AM
Dave the way i have the refueling hooked up is that a bad idea.
useing a t between the tank and the engine?
Old 05-22-2005 | 10:27 PM
The t is not a problem but they have to be in the right places in the lines.
