YS Engines Support Direct support from YS Performance Engines by Dave Shadel
DZ 140 quitting problem
Old 05-23-2005 | 02:52 AM
Default DZ 140 quitting problem
Hi Dave,
I have a DZ140 with low run time. It has been running faultlessly until recently. All of a sudden it has started to quit at idle either during spins or stall turns. I have replaced glow plug, fuel and all fuel lines.
The engine now wants to run about 1/4 richer than before. (Now at 2 turns) I have leaned of the pump which seems to cure the problem but I find the engine gets a little cranky during throttle transition to full throttle. In other words if I lean out the pump the motor wont quit but is too lean to run. If I richen the motor were it transitions nicely it will quit on idle. I have checked for leaks and reset tappets.
Using Coolpower LV with 25% nitro
OS F plug
16X12 APC
Regards,
Peter
Old 05-23-2005 | 09:57 AM
Default RE: DZ 140 quitting problem
Leaking piston ring maybe, but hard to say without seeing it.
