YS63 pump settings
Hi there
A friend of mine unfortunately started adjusting the pump screw of his YS63S, which one shouldnt [&:]. What is the factory setting of the pump? Or are there any roules to adjusting it?
Go to www.ysperformance.com and follow the running instructions.
The regulator needs to be adjusted, otherwise they would not have put an adjusting screw on it.
Put the top of the screw head even with the top edge of the regulator housing as a starting point.
