YS Engines Support Direct support from YS Performance Engines by Dave Shadel
YS1.10
Old 07-05-2005 | 03:10 PM
Default YS1.10
Hi Dave
I am looking at using a YS1.10FZ in a 19% SU26 which i am currently building, prop choice will either 16x8 2 blade or 15x8 3 blade and i am looking at using Magnum 30% Heli fuel with 22% oil content. I am trying to figure out the tank size which i will need to acheive at least 10 minutes flight and a couple reserve, any ideas?
Cheers
Old 07-05-2005 | 03:41 PM
Default RE: YS1.10
16oz.
Both props you mention are too big. Try 15x10 two blade or 16x6 two blade. Try for peak ground rpm of 9000 to 9500 for best results.
Old 07-07-2005 | 10:00 AM
Default RE: YS1.10
OK, thanks for that Dave, is the Magnum 30% fuel ok for this kind of engine?
Old 07-07-2005 | 10:43 AM
Default RE: YS1.10
It will work fine.
