YS Engines Support Direct support from YS Performance Engines by Dave Shadel
YS 63 in Funtana 40
Old 07-27-2005, 02:19 PM
Monkey Gutz69
Default YS 63 in Funtana 40
Dave,I have a Funtana 40 with a TT Pro .46..I want a FS. I was leaning toward 91 Saito, as I wanted over powered plane, and all the Funtana threads advised to way over power and use throttle control. ( I have no 4 stroke experience)Then I heard about the YS line of engines. I do not know of anyone personally who owns one, so I am at a disadvantage in YS experience, and there is not alot on the web.
I see YS no longer makes a .90 size engine, and a 110 would be to much for a 40 size Funtana, so that leaves us with a .63 YS. In one of your threads you said a .63 would be good for a 5-5.5 lb plane. Would the FZ63s pull the Funtana 40 around with authority??? This going to be my 3D plane.
I really like the idea of supercharging and not fighting with fuel tank problems,plus I read that the YS spools up faster and out torques anything in it's class.. I read that the 110 has the same power as a Saito 150, therefore ,a fz63s should be equivilant to a Saito 82???? Am I on the right track????? Thanks, MG
Old 07-27-2005, 02:37 PM
AGR413
AGR413's Avatar
Default RE: YS 63 in Funtana 40
I can't help you with the YS question, but I can tell you there are no problems with the fuel situation with the Saito .82, I am running it on my Funtana 40, I live and fly at 4000ft and this plane is absolutely ballistic on the Saito .82 with a 14x4w, 15% cool power. The YS turns the same rpm rang as the .82 and is not rated for the large wide blade props like the 14x4w. I have nothing against ys engines except that I have heard opinions that they can be trouble to tune, I have not run any. I have run the Saito .82 and can tell you that it gives the Funtana all the power you could ever want for the most extreme 3D manuvers.
Old 07-27-2005, 04:54 PM
Dave Shadel
The 63S makes about the same power as a Saito 82.
I know of guys who are flying your airplane with the 110, but it is serious overkill. How much does your airplane weigh? If it's under 6 pounds the 63 should be ok.
