YS Engines Support Direct support from YS Performance Engines by Dave Shadel
YS61 prop
Old 08-21-2005 | 12:41 PM
tIANci's Avatar
Default YS61 prop
Dave ... I got an older version YS61 long stroke. I am thinking of using her in Balsa USA Enforcer. What prop might be good for this engine? Thanks.
Old 08-21-2005 | 12:48 PM
Default RE: YS61 prop
11x10, 11x11,11x12, 12x8,12x9, 13x6,13x7. Lots of choices.
Old 08-23-2005 | 03:25 AM
tIANci's Avatar
Thanks a lot! those are huge props!!! Is the engine that good? Hehehe ... I am a happy bunny!!!
Old 08-23-2005 | 04:08 AM
ini
ORIGINAL: tIANci
Yes it is !
I run YS 61LS with Hatori 650. My favorite was 12x11 running 10600, 10 % nitro. Relatively quiet, too.
A slightly smaller prop like 11x10 will let it turn more and give more power also but will also increase noise.
ini
Old 08-23-2005 | 08:35 AM
Great!
Old 08-29-2005 | 11:52 AM
tIANci's Avatar
Dave ... am keen on using the YS61 for the Balsa USA Enforcer ... what pusher prop would you recommend? Thanks!!!
Old 08-29-2005 | 02:34 PM
I don't have a clue, really. Get something in the same size range as the tractor props and try it.
