YS Engines Support Direct support from YS Performance Engines by Dave Shadel
Adjust valves when???
Old 09-07-2005 | 10:11 PM
Default Adjust valves when???
I have five tanks of 15 % Heli fuel through through this engine I just bought 3 weeks ago..
When do I adjust the valves/?? engine works flawlessly now ...
I know they need to be T D C on compression stroke. so do I do one valve at comp TDC and then rotate twice more then do next valve at comp stroke TDC . and >003 thous.. i might add ?????
Or do I do both valves at the same time after bringing it to TDc on the compression stroke.
Thanx in advance....Popcan...
Old 09-08-2005 | 08:28 AM
Default RE: Adjust valves when???
Do it every 50 flights just to be safe. Set them both at .003" on the compression stroke.
Old 09-08-2005 | 07:30 PM
Thank you for reply, but when should I do the first adjust ,,,???? Then every fifty flights right.... thnx again...
Old 09-08-2005 | 09:06 PM
I would adjust after the first gallon of fuel, then every 50 flights thereafter.
Old 09-09-2005 | 11:05 AM
Thank you for the timely answer and I appreciate your help....
popcan
Prince Edward Island, Canada...EH!
Old 09-09-2005 | 11:20 AM
Good Flying!
Old 08-31-2006 | 10:45 AM
Dave: Would valve adjustment on a 1.40 have anything to do with engine going dead on throttle back coming in for landing? Fairly new engine... very low air time. Thanks Capt,n
Old 08-31-2006 | 11:14 AM
It would.
Old 08-31-2006 | 09:17 PM
Dave...forgot to ask...do you set vale clearance when engine is cold? Or is it better to set on a slightly warm engine? Thanks Again....Capt,n
Old 09-01-2006 | 10:41 AM
Cold
