YS Engines Support Direct support from YS Performance Engines by Dave Shadel
YS 6FZ DRIPPING FUEL OUT OF CARB
Old 11-27-2005, 10:46 PM
BRETTMAN
Default YS 6FZ DRIPPING FUEL OUT OF CARB
HI DAVE,I HAVE HAD THIS ENGINE ABOUT A YEAR WITH ONLY TEN FLIGHTS,RAN GREAT FIRST TWO MONTHS,THAN SAT A FEW MONTHS AND THAN COULDN'T GET TO RUN RIGHT.I HAD IT SIDE MOUNTED AND NOTICED ALOT OF FUEL OUT OF CARB.DIAPHRAM GASKET IS FINE ,NO RIPS.TOOK PLUNGER OUT WASN'T STICKING PUT SEEMED SLOPPY IN HOLE.ALL PORT HOLES WERE CLEAR.WAITED WHILE BEFORE PUT BACK TOGETHER WITH SAME RESULTS.QUESTION ABOUT SPRING,PUT-NARROW-SIDEOF SPRING AGAINST NIPPLE RUBBER,AND WIDER PART AGAINST REGULATOR SCREW,DID I DO THAT RIGHT?
Old 11-28-2005, 10:56 AM
Dave Shadel
Default RE: YS 6FZ DRIPPING FUEL OUT OF CARB
The plunger should probably be replaced or at least cleaned out. It may have a piece of crud holding it from sealing properly,
Old 11-28-2005, 12:35 PM
BRETTMAN
THANKS I'LL ORDER ONE,I ALREADY CLEANED THAT ONE WITH THE SAME PROBLEM. THANX YOU
Old 11-28-2005, 01:13 PM
Dave Shadel
Get a new spring too.
Old 11-28-2005, 05:26 PM
BRETTMAN
will do thanx again
Old 11-28-2005, 09:28 PM
Dave Shadel
