YS 91 Fuel question
Hi Dave,
My local hobby store just ran out of Cool Power (I was using 15%). I don't want to use the Byron fuel as it has a lower oil content.
I've found an r/c car store which stocks 25% fuel from "Model Technics Ltd." from England. I was wondering if you are familiar with the typical oil content of fuel for r/c racing cars? Would it be acceptable?
Thanks Dave.
Cheers,
Ken
Thanks Dave.
Cheers,
Ken
I've used quite a lot of this MT fuels in the past and have just recently used it again for exactly the same reasons you've had...no cp!.
I've found a fuel called quick speed that contain no castor and a nitro level I want. The only thing you need to remember is that it contains only 13% EDL oil!!!! This must be brought up to sratch by adding extra EDL!
If you go to the MT web site and check it out, you'll find lots of info plus telephone numbers.
The Guys are very cooprative and will tell you exactly the amounts of oil need to bring their fuels up to any personal spec. They just tap the ol' computer and hand over the data! Could be worse!
By the way, they make a special fuel for YS engines.
