YS Engines Support Direct support from YS Performance Engines by Dave Shadel
YS 110, is it suitable for a Segull edge
Old 03-05-2006 | 04:01 PM
Miketc's Avatar
Default YS 110, is it suitable for a Segull edge
Hi Dave, I have 2 YS 110's, one in my Ultimate 10-300 , and one in my World Models Super Chipmunk. Both Engines are running perfectly. I run in desert conditions (very high summer temps, 100 +) at sea level in Kuwait with a rich setting, Cool Power 20, 20 fuel, that great green stuff. The performance on both engines is fantastic.
My question is, will the 110 be powerful enough to fly a Segull Edge 540? I'm not into 3D flying. The recommended size is 120 to 180, but a very good review in RC Model World September 2005 copy (UK Publication) suggested a 120 would be more than adequate. Flying weight (in the review) was 6KG or 13.2 lb. What's your view?
Old 03-06-2006 | 02:23 PM
Default RE: YS 110, is it suitable for a Segull edge
Not at that weight if you want hovering performance with a vertical pullout.
Old 03-06-2006 | 03:31 PM
Miketc's Avatar
Dave, thanks for your reply,
Currently I have no interest in hovering and pulling verticals!!
What is the maximum weight I should have on a "large" plane using a YS110?
Do you have an alternate suggestion to a suitable engine? What about the YS 140 sport or the DZ?
Are they similar in ease of operation? To date I have not had any issues with either of the YS110's.
Thanks in advance.
Old 03-06-2006 | 04:05 PM
The 110 is good for general aerobatics in aircraft to about 11 pounds IF they have plenty of wing area. I think the 140 Sport would be a better choice for the Seagull. The 140 is just as easy to use as the 110.
Old 03-07-2006 | 12:39 PM
Miketc's Avatar
Thanks for the advice. My local model shop mentioned a YS140S for Special, what is the storey behind this model?
Mike
Old 03-07-2006 | 08:41 PM
It's a Sport, not a Special. It's basically a 140L with a 120 backplate assembly.
