Problems with a YS 140 sport
Hi,
I have problems with a YS 140 sport. It was running more or less fine, but after some weeks without use it, now it´s impossible to adjust it. To full throttle is ok, the problem is in idle, after 5 or 6 seconds the rpm goes up. If you open the throttle suddenly, the engine stops. I tried to re-adjust the low speed needle, but nothing happened.
I´d be grateful if someone could give me some idea to find the solution.
Best regards from Spain.
