YS Engines Support Direct support from YS Performance Engines by Dave Shadel
ys61 stII quits in flight
Old 04-08-2006 | 03:04 PM
Default ys61 stII quits in flight
HI,
I was flying my freya with a ys61st2 today. Have not flown it for 6 months. New enya 3 installed. Engine suddenly quit in flight, autoed with minor damage to landing gear and blades. Engine was perfectly tuned and running prior to storage. Post- flight inspection reveals a lot of unburned fuel pouring out from muffler and engine. Diagnosis? Anyone?
Vic
Old 04-08-2006 | 03:50 PM
Default RE: ys61 stII quits in flight
Stuck regulator from sitting for six months. Pull the reg and carb oof and clean thoroughly. Might also need a new diaphragm.
Old 04-17-2006 | 05:16 PM
Hi Dave,
I cleaned the regulator and replaced with new diaphragm. I started the engine but engine always die when the glow igniter is removed. New Enya 3 installed. I did not fiddle with any of needle settings. Could it be that rear engine bearing needs replacement? This engine was serviced by Rich Verano and he replaced rear engine bearing 1 year ago. Thanks.
Vic
Old 04-18-2006 | 10:00 AM
Hard to say. Pull the backplate off and see if the rear bearing is rusty. Are you using fresh fuel?
Old 04-18-2006 | 01:05 PM
Hi Dave,
I pulled backplate off and rear bearing is rusty. I'm using fuel I bought 6 months ago. Thanks.
Vic
Old 04-18-2006 | 04:42 PM
If it's rusty it needs fixing before you proceed.
