YS Engines Support Direct support from YS Performance Engines by Dave Shadel
YS 63 in flight problems
Old 04-26-2006 | 09:10 PM
Default YS 63 in flight problems
Dave,
My 63 is on a Pizazz and when I pull to vertical and go into a hover the engine begins to vibrate violently and then dies. Seems to run fine in level flight. The engine has run flawlessly for nearly 2 years, could I have a bearing going bad?
Thanks in advance
loopsnut
Old 04-26-2006 | 09:40 PM
Default RE: YS 63 in flight problems
I'd be more likely to think that the clunk is hitting the end of the tank and making it go lean.
Old 04-26-2006 | 09:48 PM
Thanks Dave...one thing I forgot to mention is that there is grey splatter residue on the canopy, not the usual slobber.
Old 04-27-2006 | 10:04 AM
Not a good sign. Could be that the rotor/backplate has an issue. Might be worthwhile to send it in.
Old 04-27-2006 | 08:58 PM
As always thanks Dave...I'll put in the system.
Old 04-27-2006 | 10:00 PM
OK
