For Dave, How to Store
My Feedback: (12)
Dave,
I have read several comments you have made concerning what oil NOT to use for storage of our valuable YS Engines.
PLEASE, DO tell exactly what oil or substance YS does recommend for long term storage.
Also, what is the recommended process for application of the Oil (substance). Should I squirt it down the throat of the Carb, and in the glow plug hole. Maybe hook the fuel line to a container and spin the engine through ? I assume I need to remove the Rocker cover and coat the valve train and push rods.
My particular engine is the 120 FZ.
Please tell us the right way.
Thanks, Robert.
Also, what is the recommended process for application of the Oil (substance). Should I squirt it down the throat of the Carb, and in the glow plug hole. Maybe hook the fuel line to a container and spin the engine through ? I assume I need to remove the Rocker cover and coat the valve train and push rods.My particular engine is the 120 FZ.
Thanks, Robert.
