110 FZ pressure problem
CO
Hi Dave,
I have a fairly new 110 which has flown a couple of times OK since it was in for service.
After a faily hard landing which did break the prop, I find that the engine no longer produces any fuel pressure. I have replumbed the fuel system and if I apply pressure to the line, the check valve will hold pressure in the system OK, so it must be that no pressure is coming from the engine.
A look inside regulator showed no debris and all ports clear.
Could something internal to the engine prevent it from genereating pressure ??
Jim
Jim
If it bent the crank, yes. Did it knock the airbox loose or crack it? Hard to tell what internal damage you caused without pulling it apart.
