YS Engines Support Direct support from YS Performance Engines by Dave Shadel
Ys 91 ST
Old 08-20-2006 | 02:58 PM
Default Ys 91 ST
Hi Dave,
Can one mount the 91 ST which is a heli engine on a plane such as the Venus 2??
Are YS planning a new two stroke engine for planes?
Thanks in advance
Brian
Old 08-20-2006 | 05:46 PM
Default RE: Ys 91 ST
They work just fine in airplanes, but require a "reach thru" prop nut and a drive hub so you can mount a prop on it.
Old 08-22-2006 | 12:51 AM
Hi Dave,
Where can I obtain the reach through prop nut and drive hub suitable for this engine from?
Regards,
Syd.
Old 08-22-2006 | 08:49 AM
You "SHOULD" be able to get them from Probuild, but if not, try Central. The drive hub is the same as that used on the older 61 pattern engine, and the prop nut is a Tru-Turn product.
Old 08-27-2006 | 06:51 AM
Hi Dave,
Can you please tell me what the thread size is on the output drive shaft for the YS91ST to enable me to select the correct Tru-Turn adaptor kit?
Regards,
Syd.
Old 08-27-2006 | 08:51 AM
8x1mm
