YS Engines Support Direct support from YS Performance Engines by Dave Shadel
transition question on the 110
Old 11-03-2006 | 09:20 PM
suitcase's Avatar
Default transition question on the 110
I have sent the engine to YS performance to get them to look it over. I simply can't make it run properly. One question I have is this. Once I got it to full throttle and set the high end needle, I instantly bring it back to idle, but the engine doesn't come to idle instantly. It just spools down. I believe it's supposed to come to idle instantly. I worked with it till it would transition but it still seems rich, I keep turning in the reg till it finally and only once throws the prop. Checking the reg I find it only about 1/4 turn from all the way in. Fuel poors from the carb after it dies. It seemed to act differently each time I returned it to factory and started over. I sure hope they can find out if some thing is wrong or if it's just me. I love my other one it runs great.
Old 11-03-2006 | 10:01 PM
Default RE: transition question on the 110
Call Richard on Monday. Tell him you have another 110 that runs perfectly and if he can't make this one run the same way, ask him to exchange it for a new engine. Obviously this one is a loser.
775-782-4562
9 to 5 west coast time.
Old 11-05-2006 | 04:20 AM
suitcase's Avatar
Ok I'll call him.
Old 11-05-2006 | 10:02 AM
Keep trying if the phone is busy. Mondays are pretty bad sometimes.
If you encounter any problems with this, feel free to call me at 775-265-7523.
Dave
