YS Engines Support Direct support from YS Performance Engines by Dave Shadel
YS 120 Muffler
Old 01-03-2007 | 09:12 PM
reyn3545's Avatar
Default YS 120 Muffler
Dave,
My YS 120 (very old) came with just a curved pipe exhaust, and I want to move to something quieter.... do all 120's have the same exhaust threads?
Old 01-03-2007 | 09:29 PM
Default RE: YS 120 Muffler
They do. All YS 91 thru 160 use a 13x1mm thread in the cylinder head. Try www.pspec.com for a muffler.
Old 01-03-2007 | 10:56 PM
reyn3545's Avatar
will do.. I haven't been too happy with Pitts mufflers on 4-strokes, so I think one of their bullets might work just fine.
One other quick question before I get my drill out and ruin something.. I've seen other posts where you're recommended drilling a 1/8 hole in the throttle inlet to assist with idle smoothness... does this hole go in the large side of the throttle butterfly? I just want to confirm first.
Old 01-04-2007 | 01:14 PM
Don't open up the airbleed hole unless it idles too rich. Then only drill in .005" increments until you get it right. 1/8" is way too big a step from the stock hole size in the barrel.
Old 01-04-2007 | 07:08 PM
reyn3545's Avatar
Thanks.. glad I asked.. it does idle a little rough on the test stand, but I'm not sure that its not a simple tuning issue. However, there's not a lot to adjust for the low end on this plane.
Thanks again for the advise.
Old 01-04-2007 | 07:20 PM
You can try leaning the regulator 1/8 to 1/4 turn.
