camshaft timing on ys 140L
Hello,can somebody please tell me how to set up the timing marks for the camshaft and crankshaft on a ys 140L.Thank you in advance for your help.
RE: camshaft timing on ys 140L
The two dots (one on the crank web and one on the camshaft) need to be both at the bottom. Note that the mark on the crank isn't exactly lined up with the crankpin - ignore the crankpin and go by the mark. Remember too that the cam will twist as it goes in, so you may need to try a couple of times to get it to line up once it's in place.
James
James
