Fuel tank position
Hi Troy,
Does the height of the fuel tank in relation to the engine ( YS 63 FZS ) have an effect or does the pressurized system overcome this issue?
I would simply like to install a larger tank on my Reactor and the only place is approx 7 cm below the carburetor line.
Thanks in advance
Brian
Thanks in advance
Brian
The pressure system eliminates most of these issues. If the change is extreme then its still not the best of solutions but in your case its not an issue.
If the tank was mounted in the tail of the model or maybe out in a wing tip then the possible line loss in the fuel tubing could be an issue....If the tank is within about 12-18" of the engine it is fine and vertical distance is not really an issue within reason as well.
Troy Newman
Team YS
Troy Newman
Team YS
