replacing the YS160 with the YS170
Dear Troy,
I have an Oxalys ship with YS160DZ install on a Hyde mount with Central Hobbies nose ring with Hatori Header & Muffler #821 and #822.
I was told that replacing the 160 with the 170 requires no changes whatsoever and all is compatible. Can you be so kind and confirm that this is the case...
Any special instructions to break-in the 170
Thank you in advance
Amram Leshed
F3A Israel
Amram Leshed
F3A Israel
Correct no changes needed. Same weights within a few grams and all the 170 is a little taller by about 1/16" and that is about it.
Powerwise the difference is a little...I would say 1 prop size if that.
Troy Newman
Team YS
Troy Newman
Team YS
