YS Engines Support Direct support from YS Performance Engines by Dave Shadel
Prop advice
Old 03-19-2008 | 01:25 PM
Default Prop advice
I have a 140L which I'm going to fit in a 1/4 scale Super Cub.
I'll be running it on 20/20 and sometimes using it as a glider tug.
Scale prop dia is around 19" (so 18"-20" would be good) and when not using it as a tug I'd like to be able to fly it at a scale speed.
What size/s shall I go for?
Old 03-19-2008 | 02:04 PM
Default RE: Prop advice
you can try lots of differnt props. You should run a prop that turns about 8400-8800rpm. I know that a 16-10 on the fuel you are using will work in that rpm range.
I don't think you are going to get a prop that runs well enough that is 18-19" diameter....in the right rpm range.
The main reason is props get heavier with larger diameter and that will add additional load to the engine. SO you will have to go to a very flat pitch prop and it will rev up higher but its addition weight will add load and the engine will not like it.
To get scale flight performance I suggest using the throttle to reduce power.
Try some props but I think your engine will be happy with the 16-10 or 17-8 props. Given your 20/20 fuel mix. Even going to higher nitro like a 30% fuel you are only going to get one prop size and usually its a pitch size and not a diamter.
We are currently running 170DZ's on 17 and 18" props. The 170DZ has a ton more HP than a 140L
Troy Newman
Team YS
Old 03-19-2008 | 02:35 PM
Thanks for the info Troy,
What about a carbon 18x6?
