low speed needle closed = cw or ccw???
FL
this may be the all time stupid question but here goes....
on the low speed adjustment it says to open the low speed needle 1 turn from fully closed.
because lean is counterclockwise (ccw), is all the way ccw closed? then go 1 turn clockwise (cw)?
thx
gator
thx
gator
FL
RE: low speed needle closed = cw or ccw???
thanks!
I'm struggling with tuning the low end and have to eliminate 1 variable at a time!
Gator
Gator
What size engine do you have? There's a known issue with some of the 140 Sport engines where a hole in the carburator barrel was not drilled correctly from the factory. They're drilled too small. If that's your engine, could be your problem.
David
David
