YS Engines Support Direct support from YS Performance Engines by Dave Shadel
ys 53 help
Old 09-01-2008 | 07:25 PM
Default ys 53 help
it seems that when my engine gets warm, the butterfly in the carb starts to bind. what might be causing that?
thanks
rome
Old 09-01-2008 | 07:43 PM
petec's Avatar
My Feedback: (58)
Default RE: ys 53 help
Loosen and retorque the carb body bolts.
Old 09-01-2008 | 08:21 PM
would that be the carb screw?
Old 09-01-2008 | 08:26 PM
petec's Avatar
My Feedback: (58)
That would be the four screws that hold the cab body to the engine case. I only suggest that because I had an engine that exhibited the same issue and it was due to uneven torque of the bolts.
Old 09-02-2008 | 04:22 PM
i think i got that, its nice and loose now. but i notice bubble starts to appear on the fuel line the line that goes to the carb
Old 09-03-2008 | 08:11 AM
petec's Avatar
My Feedback: (58)
A few little air bubbles in that line, especially at or around idle, are normal. a lot of big air bubbles or bubbles that do not go away at higher RPM are not normal.
