YS Engines Support Direct support from YS Performance Engines by Dave Shadel
Ys 52 4s
Old 07-01-2003 | 02:01 AM
My Feedback: (27)
Default Ys 52 4s
I just bought a plane with a YS 52 4S. First, I need to get a copy of the instructions, as they didn't come with the plane.
I am having trouble with the engine running fine on the ground but dies in the air. There also seems to be excessive pressure in the tank. Hopefully, the directions will help to make sure the engine is set up right. Thanks.
Old 07-01-2003 | 08:06 AM
My Feedback: (182)
Default Ys 52 4s
I believe you are talking about 53FZ.
http://www.yspower.co.jp/pdf/fz53-2e3.pdf
Instruction is PDF file, so you will need acrobat reader.
Hope this helps,
