YS Engines Support Direct support from YS Performance Engines by Dave Shadel
DZ problems
Old 07-08-2003 | 01:00 PM
Default DZ problems
I have a problem with my Dingo, it won't react to my main needle, I can have it at 5 turns out or at 2 turns but it runs the same +/- 8200 rpm on an APC 16.5-12 Wildcat 30% heli
I'm thinking it might have an air leak somewhere.
Can you help me with this problem?
John
Old 07-08-2003 | 02:18 PM
Default DZ problems
Sounds like a bad pump. Try turning the pump screw in about 2 turns and see if it helps.
Old 08-04-2003 | 05:27 PM
Default DZ problems
Hello Dave,
I'm still having problems, I turned the regulator in but its still the same.
Maybe I'm expecting it to to behave like other 4 strokes but it doesn't?
If i have the main needle out 5 turns should it be extreemly rich I mean like sputtering rich? Or does this motor not work that way?
It is working perfectly idles like a dream, transitions great, but I cant get it to go realy rich.
I even tried changing to coolpower 30% heli and changing the fuel filter.
Please let me know.
John
Old 08-04-2003 | 06:00 PM
Default DZ problems
The pump is bad. Please return the engine to us for repair.
Dave
Old 08-05-2003 | 05:54 PM
Default DZ problems
I'll send it today via Fedex.
