RCU Forums
-   YS Engines Support (https://www.rcuniverse.com/forum/ys-engines-support-197/)
-   -   120 identification (https://www.rcuniverse.com/forum/ys-engines-support-197/1235161-120-identification.html)
2befast 10-28-2003 04:17 PM
120 identification
How can I tell the differences between the different models? I have one but the only thing on it is F-120. Can someone help? I can send a pic in a couple days(have to get my camera back).
thanks, Randy
Dave Shadel 10-29-2003 11:03 AM
RE: 120 identification
Need pix of rear and left side.
2befast 11-05-2003 10:25 PM
1 Attachment(s)
Hello Dave
I finally got the pics that you need to identify my 120. Can I get some specs on it? Opinion?
Thanks, Randy
Dave Shadel 11-11-2003 09:38 AM
Looks like the early F120. Not nearly as much power as the later ones. Try a 15x8 or 16x6 prop.
rmm 07-04-2004 01:29 PM
1 Attachment(s)
Hi Guys,
I also have a YS F-120 and would like to know what type it is in order to get the proper spare parts.
can you help me on this?
Rainer
Dave Shadel 07-04-2004 05:21 PM
120 FS, looks like it hit the ground. Pushrod covers are the same on all 120's
rmm 07-05-2004 04:28 PM
120 identification
Dave,
What do you mean with "it looks likr it hit the ground?"
Don't get it - it's probably my poor english -well ...
Nevertheless, I want to order a gasket set and a muffler. The muffler shouldn't be a problem but the gaskets are different - aren't they? Which one do I need to order?
Regards
Rainer
Dave Shadel 07-05-2004 04:49 PM
From the photo it looks like one of the pushrod covers is bent. Probably just the photo.
You need a YS 0900 gasket set. Try Central Hobbies.
jpe 12-27-2004 05:30 AM
Excuse me for upping this old thread...
I have similar early F-120 with a broken crankcase (large cracks both sides).
Because I have quite huge amount of unused spare parts to the motor (cylinders,pistons,ball bearings...), I'd need unbroken F-120 crankcase.
So is it possible to use for example 120SC crankcase with early F-120 pheripheral? Or some else 120 model's one maybe ?
Dave Shadel 12-27-2004 11:20 AM
We can probably match a crankcase for you. Send the broken one to us and we will see about getting you another one.
Performance Specialties
P.O. Box 3146
Gardnerville, NV 89410
USA
jpe 12-28-2004 01:00 AM
My friend is a professional aluminium welder so it came to my mind if we should give a try to weld the cracks.
Is it at all worth to try?
I may of course send this one to you, but mail already costs quite a bit from Finland to US and back. And takes at least a couple of weeks...
But if you may have suitable and favourable used/new crankcases, I'll mail this broken one to you ofcourse.
Dave Shadel 12-28-2004 10:22 AM
The welding will distort the case and it will become unusable. Believe me, I have tried this before and it never works.
We have parts for the engine, but need to know exactly what you have before we can replace it.
jpe 12-29-2004 01:27 AM
Ok, I believe you.
I'll mail this to you. It indeed takes about two weeks and of course there are couple of customs too.
Let's hope it arrives.
Thanks.
Dave Shadel 12-29-2004 11:12 AM
We'll be looking for it.
jose_ribeiro 04-01-2005 09:43 AM
Dave, i´m bying one used engine that is the same "F-120", how less powerfull it is comparing to one ys 120FZ ?
I mean turning a 16x6 prop, what´s the RPM diference betwen the two engines?
Thanks very much.
Jose Roberto.
jose_ribeiro 04-01-2005 09:46 AM
Thanks very much.
Jose Roberto.
Dave Shadel 04-04-2005 11:17 AM
Close to 1000 rpm difference.
jpe 04-07-2005 01:55 PM
I decided after all that it's just too expensive to mail the broken crankcase, discussed earlier in the thread, to you.
But can utilize F-120 spare parts maybe in some other newer YS model ?
Cylinder, piston, bearings for example? I have 3 new pieces of them all...
If not, I just must try to find used F-120 one.
Dave Shadel 04-07-2005 09:17 PM
None of the parts are compatible with any current engine.
jose_ribeiro 04-10-2005 11:49 PM
Dave, is there any power diference betwen the 120 nc and 120 fz ?
Is the weight the same?
What RPMs is recomended for each one?
Tank you very much.
Jose Roberto.
dinoslmn 04-11-2005 02:28 AM
Hi Dave,
can you check if i can replace F-120 (old engine) regulator with a new style ( teflon membrane) one ?
Thank,
Dino
Dave Shadel 04-11-2005 08:46 AM
The regulators on all the 120's are the same. YS part number 0730 for the diaphragm.
jose_ribeiro 04-11-2005 08:57 AM
ORIGINAL: Dave Shadel
Dave, do you work for YS?
If so, please, answer my question?
Thank you very much.
Jose Roberto.
jpe 04-11-2005 01:14 PM
How about these F-120 spares to other newer 120 models?
Dave Shadel 04-11-2005 08:52 PM
Many parts are the same. The diaphragms are the same in all the 120's that YS ever made.
Obviously I can't list all the parts which interchange between all the models, but there are quite a few. Can you be more specific?
