RCU Forums
-   YS Engines Support (https://www.rcuniverse.com/forum/ys-engines-support-197/)
-   -   when to overhaul a YS ?????? (https://www.rcuniverse.com/forum/ys-engines-support-197/2006554-when-overhaul-ys.html)
wood 07-20-2004 08:38 AM
Dave,
How do I know when my 63 might need a rebuild/overhaul? How many gallons of fuel can I run through it before it is basically worn out?
Wood
Dave Shadel 07-20-2004 09:43 AM
RE: when to overhaul a YS ??????
Impossible to tell, really. If the engine has good compression, isn't making any funny noises like bearings falling apart, I would say just run it until it dies.
We've had many customers get 500 plus flights with virtually no maintainance other than setting the valves once in awhile.
wood 07-21-2004 02:50 PM
Dave,
What would be a good way to measure the compression on a 63?
Wood
Dave Shadel 07-22-2004 09:24 AM
When any model engine begins to lose it's seal, the top end power will be decreased, the ability to idle will decrease. It's pretty easy to tell by just turning the engine through the compression stroke while it's still warm from a flight. If it feels wimpy, it probably needs repair.
wood 07-23-2004 10:38 AM
Dave,
On my 63 FZ, would the typical rebuild be a ring and liner, or piston, ring and liner, or a little more involved than that?
Wood
Dave Shadel 07-23-2004 01:41 PM
Maybe only the ring, maybe all three.
wood 07-23-2004 10:49 PM
Thanks Dave. I appreciate the info.
Wood
Dave Shadel 07-26-2004 11:45 AM
No problem, good flying.
