RCU Forums
-   YS Engines Support (https://www.rcuniverse.com/forum/ys-engines-support-197/)
-   -   YS 110 pump (https://www.rcuniverse.com/forum/ys-engines-support-197/3233318-ys-110-pump.html)
Toucan 08-05-2005 04:02 AM
YS 110 pump
Hi Dave,
Is there any way to know that th pump is working fine or not. I opened mine I found the plunger was stuck having black spots inside.
I would appreciate if you could kindly help.
Sharad
Dave Shadel 08-05-2005 09:20 AM
RE: YS 110 pump
IF it is not working properly, the engine will not run.
The black crap in the regulator is from your fuel. If you leave raw fuel in the engine it will be destroyed. Run the engine dry and disconnect it from the fuel tank when you are finished flying for the day.
Toucan 08-05-2005 11:18 AM
RE: YS 110 pump
I bought this engine from singapore hobby. They told me not to run the engine dry. I do not know every body tell me something different. Kindly tell my the Pump plunger was stuck in a new engine. I feel people should not buy the 110.
Dave Shadel 08-05-2005 08:05 PM
RE: YS 110 pump
You are entitled to your opinion as is the source where you bought it. We recommend running the engine dry after flying and it works for us. Any raw fuel left in the engine will draw moisture and cause corrosion.
Since we cannot get enough YS 110 engines to satisfy the demand, few people share your opinion.
Good Luck!
