YS 63FZ Problem
I picked up a used YS 63FZ, and put it on my test stand today. After putting fuel in the tank, and turning it over several times by hand to pressurize the tank, I moved the throttle to an idle setting, hooked up the glow igniter, and by the time I went to spin the prop with my starter, fuel was running out of the carb. This is only my second YS engine (the other is a 91FZ), but I'm thinking it's a regulator problem. I released the tank pressure, poured the fuel out of the carb, and trying starting it, but raw fuel was spraying out of the exhaust.
Any suggestions? Mike |
RE: YS 63FZ Problem
Sounds like the regulator is not closing....either debris, trash, or a damaged part is keeping the regulator from closing.
Troy Newman Team YS Performance |
RE: YS 63FZ Problem
Troy,
Do you recommend taking the regulator apart and flushing? What's best to flush it with?...is Isopropyl alcohol ok? Mike |
RE: YS 63FZ Problem
flush it with clean filtered RAW fuel. That is what I use.
Troy |
RE: YS 63FZ Problem
I'll give it a shot. Thanks!
| All times are GMT -8. The time now is 03:42 PM. |
