Muffler Pipe Thread Size
Troy,
One last question and I'll stop bugging ya. I want to cut a portion of the muffler pipe off to better accompdate my cowling exit . I plan on using the jam nut (threaded on the pipe above the cut) as a thread chaser after making the cut, but would feel better if I had the proper size die in case the jam nut doesn't quite straighten out the threads. What size is the pipe thread at the muffler end? |
RE: Muffler Pipe Thread Size
Oh that's one I don't know.
I'll check and get back with you. Troy |
WOW! Do I win a prize for stumpming ya. I think this might be a first. [:-]
Thanks for looking it up. [8D] |
The exhaust thread is 13x1mm, same as all YS's from 91 to 170. The 53/63 are 11x.75mm The muffler thread is 11x.75
correct 13 x 1mm
Thanks.............
| All times are GMT -8. The time now is 08:56 PM. |
