RCU Forums
-   YS Engines Support (https://www.rcuniverse.com/forum/ys-engines-support-197/)
-   -   YS .63 Problem (https://www.rcuniverse.com/forum/ys-engines-support-197/711556-ys-63-problem.html)
candiani 04-21-2003 02:54 PM
YS .63 Problem
Hi to all-
Another YS .63 question to you all...
My YS .63 never ran like it should, I am in Mexico City at 7,200 ft above MSL, using 20/20 and a APC 14x5n which reaches 10,800 rpm's n/p, however it hesitates in idle and if I move my plane also in idle to vertical position the engine quits, I checked everything again and again..I have good fuel presure(check valve in rigth direction), regulator valve in shalow position and low end valve I think is ok because transition presents no problem...by the way engine is in inverted position(Kyosho Magestic 1400 semi-patern plane).
Thank you for reading this....any suggestion will be appreciated.
Dave Shadel 04-23-2003 11:52 PM
YS .63 Problem
Idle is set too lean. Close the airbleed screw 1/4 to 1/2 turn and see how it acts.
candiani 04-25-2003 01:42 PM
YS .63 Problem
I will try again this Sunday.......
Thanx Dave.
