ZDZ & RCS Support Direct support from Mike Dooley of RC Showcase for all your ZDZ and RCS Engine questions.
Preferred Oil ?
Old 11-05-2002 | 08:02 PM
My Feedback: (12)
Default Preferred Oil ?
Hello,
Is there any preference towards the oil used with the gas ?
Amsoil is not available in my country.
Are garden/chainsaw oils etc just as suitable ?
Old 11-05-2002 | 09:17 PM
Dear Sir, You must use an oil, preferably a synthetic that can be mixed to the ratio required. It also must be suited for air-cooled 2 cycle engines. A good 2 cycle motorcycle racing synthetic oil is often used.
Mike Dooley
RC Showcase
Old 11-30-2002 | 12:41 AM
GaryM's Avatar
My Feedback: (14)
Default 2-Stroke Oil
You might check the motorcycle shops for the brand name Bel-Ray. They have been producing racing oils etc for years. Look for Bel-Ray, Si-7 Synthetic, 2-Stroke Oil. It is recommended at 50:1 when used as a premix formula. Like Mike above said, make sure it is for air cooled engines. Some people try to use oils intended for 2 cycle water cooled engines and that is not usually a good ideal.
You might also go to Amsoils web-site and look into ordering direct from them or becoming a small dealer in your area for their products. They have based most of their marketing off of small dealers working out of their homes. Their web-site will explain what I am talking about.
Good Luck Gary
Old 02-08-2003 | 06:08 PM
BigBirdFlyer's Avatar
My Feedback: (13)
I use 3W synthetic oil mixed 80 to 1. You can by it from Aircraft International.
Old 02-08-2003 | 07:05 PM
We recommend that ZDZ/RCS engines be used at a minimum of 2.56oz/gallon(50:1). Any fuel mix with a lower oil content(51:1 and above) we simply DO NOT recommend and will have the potential for engine damage.
Mike Dooley
RC Showcase
Old 02-09-2003 | 03:04 AM
My Feedback: (13)
Thanks for the reminder.
Old 02-09-2003 | 03:22 AM
My Feedback: (12)
I am going to be using Belray Si7 synthetic since its the only 2 cycle synthetic I can find in my country.
Old 02-16-2003 | 12:31 PM
747drvr's Avatar
Mike Dooley
RC Showcase
I'm new to this so please excuse my ignorance. Don't you determine the ratio yourself simply by the amount of oil you add or are there minimum and maximum ratios specified by the oil manufacturer? In other words, can't all oils be used to get a 50-1 ratio ?
Old 02-16-2003 | 09:22 PM
My Feedback: (13)
Yes. They can be mixed at what ever level you need. The oil manufactures usually state how much to mix to get the 50 or 80 to 1 mix that you need.
I hope this helps.
