RCU Forums
-   ZDZ & RCS Support (https://www.rcuniverse.com/forum/zdz-rcs-support-204/)
-   -   ZDZ octane requirements (https://www.rcuniverse.com/forum/zdz-rcs-support-204/313664-zdz-octane-requirements.html)
lennyk 10-14-2002 12:08 AM
What's the minimum octane requirements for ZDZ engines ?
I suspect in my country the 93 octane may not be available.
RCSHOWCASE 10-14-2002 10:50 AM
Octane
Use the highest you can find and you will be OK.
David
RC Showcase
lennyk 10-14-2002 11:28 AM
I just found out that the best we have is about 90.5/91
Where do I go about purchasing a ZDZ 80 ? Is it
available online only ?
Also I understand that these engines require a little creativity
to mount due to the rear carb etc and I may need standoffs or
something.
David, advise what I need to look forward to doing before building the plane.
L
RCSHOWCASE 10-14-2002 02:08 PM
ZDZ 80
You may purchase on our website: http://www.rcshowcase.com
Mounting the engine has proved NOT to be a problem at all, and has the benefit that the rear mounted carb is much quieter because of its location. Sometimes standfoffs are required and sometimes just cutting a hole for the carb in the firewall and mounting the engine directly to the firewall is all that is required.
David
